Se può servire ecco le specifiche che l'auto deve avere per il carplay :
While most current implementations utilize USB to connect to an iPhone, Apple allows use of a Lightning connector via a dock or custom cable solution. In addition, Apple has requirements for audio and noise cancellation features, such as recommending hardware be capable of 24 bit 48kHz audio (but allows 16 bit at a lesser sample rate). It also allows a vehicle to send sensor data to an Apple device including estimate range remaining, engine type, outside temperature, and more.
Other requirements include a display with a minimum 6-inch diagonal display with a minimum resolution of 800 x 480 and 30 Hz refresh rate, and a tactile hardware button for Siri (in some cases located on the steering wheel).
Apple will have all of its CarPlay hardware go through the MFi program, which means the product will require an authentication chip that aims to prevent unofficial products from offering the CarPlay feature.
