Discussione aperta da BetaQ4 il
[GUIDA] Abilitazione chiave americana con tasto accensione motore
#261
informati bene, la mia chiave originale alfaromeo non cinese. Buona vita
ENG le aveva cinesi poi ripristinate…….io sono informato bene………buona vita a te
  • FullSizeRender.mov
    13.3 MB
    928.1 KB · Visualizzazioni: 333
Ma io non le ho comprate da ENG Custom.
#264
Reazioni: luvec74
#266
Aggiungo l'estratto dal manuale USA che spiega come funziona il Remote Start e le sue peculiarità, per coloro che l'avessero attivato:
Remote Starting System:
This system uses the key fob to start the engine conveniently from outside the vehicle while still maintaining security.
The system has a range of at least 300 feet (91 meters)
The remote starting system also activates the climate control (if equipped), the heated seats (if equipped), and the heated steering wheel (if equipped), depending on temperatures outside and inside of the vehicle.
Note:
The vehicle must be equipped with an automatic transmission in order to include remote start.
Obstructions between the vehicle and key fob may reduce this range.
How to use Remote Start:
All of the following conditions must be met before the engine will remote start:
-Gear selector in PARK (P).
-Doors closed.
-Hood closed.
-Trunk closed.
-Hazard switch off.
-Brake switch inactive (brake pedal not pressed).
-Battery at an acceptable charge level.
-PANIC button not pushed.
-System not disabled from previous remote start event.
-Vehicle alarm system indicator flashing.
-Ignition in the OFF mode (if equipped with keyless ignition system).
-Fuel level meets minimum requirement.
Remote Start Comfort Systems — If Equipped:
When Remote Start is activated, the heated steering wheel and driver heated seat features will automatically turn on in cold weather. These features will stay on through the duration of remote start also until the ignition is cycled to the ON/RUN mode. Remote Start
Windshield Wiper De–Icer Activation — If Equipped:
When remote start is active and the outside ambient temperature is less than 39°F (4°C), the Windshield Wiper De-Icer will be enabled. Exiting remote start will resume previous operation, except if the Windshield Wiper De-Icer is active. The Windshield Wiper De-Icer timer and operation will continue.
#267
Io la chiave l'ho comprata su eBay da venditore americano costo 60€+ 10 per codificare la chiave in Officina e poi già avendo il multiecuscan ho cambiato il byte sulla configurazione del proxi.
Ciao, la chiave che hai acquistato da ebay va bene?
Mi mandi il link del venditore?
#269
