Discussione aperta da fedealbo il
Spider Bose - sostituzione radio
fedealbo
Autore della discussione
27 Dicembre 2022
2
Lombardia
Spider (939)
#1
Buongiorno amici alfisti. Sono da poco possessore di una Spider 1750 tbi con impianto Bose e comandi al volante. Vorrei sostituire la radio originale e metterne una un po’ più moderna, mantenendo tutte le funzionalità di comandi al volante ed impianto Bose. Questo pacchetto secondo voi va bene? JVC Lenkrad Bluetooth USB MP3 CD Autoradio für Alfa 159 Brera Spider | eBay
#2
Hello, I know about your question, but I don't speak Italian. I hope it won't cause a problem for you. For Bose integration you need to know the amplifier input power in your car. I integrated the Alpine ilx-F309D into my alfa romeo mito and it had a preamp output with 4V. It should be 6V for my BOSE amplifier but I installed it anyway. As a result the maximum volume is 25% lower than it should be but other than that it works perfectly.
If you have higher output than your bose input at JVC, your amplifier can burn (or make distortions at sound) so better to learn about amplifier input first. Alternatively you can cancel whole amplifier and directly connect your speakers to JVC. Most people doing it because it is way more easier. But I dont know how it effects audio quality.
