Infotainment my20 su Giulia my19
Ciao a tutti,
Scusate se mi intrometto nella discussione. Ho fatto l’aggiornamento da my18 a my20 sostituendo:
Body
Etm
Tft
Schermo centrale
Sensore crepuscolare
DNA
Adesso mi ritrovo con un problema sul lavavetri, gli spruzzini non funzionano. Qualcuno ha avuto lo stesso problema ? Va sostituito anche il motorino dei tergi?
Hi, you need a new MY 20 body kit or one that's been restored to its original state. In both cases, you need to write the VIN and proxy to the bench. Then, when you install it, you need to glue the old proxy, modifying the wireless and twilight sensor bytes, which you'll need to replace with a mid-2018 model or later. You'll then need to write the PIN code previously read from the RFH control unit with Alfa OBD to the new body kit. When replacing the body kit, you'll also need to modify your old wiring harness by installing the MY 19/20 DNA and modifying it to add wireless charging. You can also directly install the new MY 20 tunnel wiring harness, but you'll still need to modify it slightly.
If you want you can go ahead with radar, camera, my20 steering wheel light switch with hand presence sensor and steering box motor, but this, if you are not interested in ADAS 2 is not necessary, there will be some communication errors diagonally but everything will work correctly
Hi, friend
I have replaced the ETM MY20 and IPC MY20.
I purchased a second-hand BCM MY20 and paid someone to modify the VIN (but it was done on vehicle not on bench). When I tried to use Alfa obd to transfer secret key from RFH, it reported an error. Is there any way to solve this problem?
Thanks.
    230.4 KB · Visualizzazioni: 8
Ciao a tutti,
Body
Etm
Tft
Schermo centrale
DNA
Non c’è nessuna attinenza con il motorino lavavetri.
Salve a tutti!
Avendo lo schermo da 6.5" che comincia a rovinarsi volevo fare l' upgrade allo schermo da 8.8".
La mia Giulia monta l' ETM di 2° generazione, e avrei trovato a poco uno schermo 8.8" touch.
Sarebbe possibile usarlo comunque con il mio ETM limitandosi a non far funzionare il touch?
Perché l'idea futura sarebbe quella di completare l'upgrade con l'infotaiment completo my2020 e così intanto mi avvanteggerei.
