Shaking/Noisy undrivable after long distances GQV 2015
E più o meno la spesa quanto mi verrebbe a fare?
Mm. Left driveshaft maybe is bad.
They removed both drive shafts And they seem perfect to them.
No issue can be found (mechanical).
But still when I press the gas it shakes. and after long use also braking shakes...
Can it be a caliper or ABS issue causing all these? and maybe the tires are done after the brakes issues?
Any news about that?
We would have like to help you but we couldn't say how to.
You said a lot of jobs and checks have been done:
Driveshaft?
Suspension arms?
Callipers and pads?
Tyres?
Abs sensor and electronics?
Steering shafts?
Steering box subframe?
Engine silent block?
Then we didn't heard nothing about you, did you solve the problem or did you give up?
How is your QV now?
Reactions: qvtct15
It was fixed after suffering.
The problem was on the master cylinder which was keeping the brakes touching constantly
only the Front right and rear left where affected.
the ABS was not giving any strange signs cause the touching was little
Under cold winter the problem was not there due to fast cooling, when the weathe rwas getting warmer, the problem was more and more obvious
Due to this also the front right bearing gave over time and an engine mount due to the constant shaking of that corner.
Now the car for 2000km drives good. the tires are a bit off due to that, but I put them back
Reactions: qvtct15
I’ve not ever heard a problem like that!
I had that problem on an high mileage minivan the master cylinder was worn and didn't recover after brake. But it was action was only on rear wheels
