Discussione aperta da orioneit il
[GUIDA] Installazione sensori di parcheggio aftermarket
#492
E' possibile regolare in qualche modo i sensori di parcheggio a livello di sensibilità?
Il bip fisso a 30cm mi sembra un po' troppo, soprattutto nelle manovre più di precisione...
#493
No.
#494
At start - I'm sorry for that I'm writing in english, but I read Yours forum by use of translator (I don't know Italian at all).
I had 2012 Giulietta with oryginal rear parking sensors.
I bought new control unit 50528306 for front and rear sensors and one buzzer / speaker (46555998).
Now questions:
- I know there will be only rear sensors displayed, but what about buzzer in cluster - will it work or I need to buy second buzzer?
- can I use any other sensor from Valeo (e.g. from VAG cars or any other)?
- front sensor harness - can I use rear one (I know there are two connectors for plate light, but it can be insulated).
#495
Now questions:
Only restyling Giulietta from 2014 support front sensor. Your not I’m sorry.
#496
Officially I know. But I read some post about that on polish forum and it should to work, but user which made it doesn't respond anymore. That's why I ask here. If understand it well, I need BCM from 2014+. Besides of that - buzzer and sensor. From VW will work because on some auctions say it should.
#497
If you change BCM with one of 2014+ successfully and I don’t know how I think it can work. You need sensor control unit front+rear, cables with sensors, two buzzers and switch near s&s switch. Then activation with Multiecuscan or AlfaOBD.
Reazioni: rpg90
#498
Switch is necessary or just as option?
Again what about those "universal" VAG/Fiat sensors? Will they work?
#499
Switch is a part of electric scheme but work even without. For sensors type I think are The same of vw Citroen Peugeot etc that mount valeo.
Reazioni: rpg90
