Discussione aperta da RandolphCarter il
Giulietta MY14 - Sistema Multimediale Uconnect [INFO POST PAG.1]
#4,911
Bit 74 = 0A efficient drive
Bit 118 = 80 APPS
I think for all indicators working on Alfa Performance need body almost with fw 2.16 or up.
Thanks.
Body is the same, so fw is the same and normally I should have the same indicators for all the three different head units I tried.
I did not get Bit 74 and Bit 118. Can you please explain?
#4,912
See these pictures.
Count 74 and 118 byte in the first.
And verify the fw in the second where you see 0205 and you need 0216 and up
    179 KB · Visualizzazioni: 215
    102.9 KB · Visualizzazioni: 194
#4,913
Ευχαριστώ. Μπορώ να αλλάξω αυτές τις τιμές με το mes;
Do you have any idea about the flashing odometer? I am saying again that I tried MES Alfa obd and wi tech but all of them failed
#4,914
se i servizi live, sono finiti, come a me, non c'è modo di riattivarli, ho già fatto reclamo per mail a FCA, e mi hanno risposto con un NO secco, se voglio posso comprare il mopar connect, secondo me a fare questi giochetti poco trasparenti, perdono di nome
Reazioni: Ro60 e spiderman58
#4,915
Ευχαριστώ. Πώς μπορώ να κάνω προσαρμοσμένο διακομιστή μεσολάβησης με το mes; Δεν μπορούσα να το βρω.
,Live services end by the end of the year for everyone? I am not sure
#4,916
Anche a me sono scaduti a novembre 2021, non riattivabili. :(
#4,917
About custom proxy can you help? I have 3.8 registered version of mes and also I have Alfa obd
#4,918
You can do it with MES but only increasing the existing total km registered on the odometer.
#4,919
Sorry for my many questions. I can’t understand how total Km are connected with custom proxy on mes. Can you please provide screenshots step by step?
#4,920
in effetti , a causa di questo, ho perso molta credibilità in alfa romeo,perchè al momento dell'acquisto, nessuno, dei venditori, e nemmeno sul configuratore,veniva menzionata la scadenza di tali serviziora ,ora ci troviamo un sistema uconnect, funzionante solo in parte, e senza la possibilità di un rinnovo, nonostante abbia già aperto un reclamo in alfa romeo , che secondo loro esiste solo il l'acquisto del mopar connect con ben 450 euro di costo...
senza ovviamente interfacciarsi con il nostro sistema multimediale, ma sarebbe visibile solo su telefono
