Giulietta - E' possibile far montare aftermarket navigatore tom tom
allora queste sono le stringhe del programma blue&me che sono dentro il sw della centralina
Database Id: {359CBA00-E461-F872-8763-650CC1966967}
Entry id / size: 0 / 2896
Package Id: {456A78B7-25DC-4811-BBB6-2BDC8BB8DFE1}
Super Entry Id: {00000000-0000-0000-0000-000000000000} 0
Order: 129067778920000000
State: 'ES_INSTALLED EF_EVENT EF_NONINTRUSIVE ' ( 0x01002020 )
Session: 0x00000000
Name / Provider: 'BM_ReadyV2U' / 'CRF'
File location: '\Hard Disk\BMd_N_L_4_TomTomLau_199_10130_F.ARM926.CAB'
Target: '\UserData\BM_ReadyV2U'
DevMgmt Id: ''
OEM String: ''
Version: 1.0.13.1
Errors / hr: 0 / 0x00000000 S_OK
Shadow Id: {00000000-0000-0000-0000-000000000000}
Reserved: 0x00000000 0x00000000 0x00000000
Checksum: 0x6b977d3d
Dirty/Backup: 0x00000000 0x00000000
Database Id: {508EB400-1489-1ABC-6ED5-6B7F3005BA2F}
Entry id / size: 1 / 2896
Package Id: {00000000-0000-0000-0000-000000000000}
Order: 129069305820000000
State: 'ES_INITIALIZED EF_CACHED EF_FORCE EF_NONINTRUSIVE ' ( 0x00200a28 )
Session: 0x40000000
Name / Provider: 'fastdevicelogging' / 'Microsoft'
File location: '\Hard Disk\SFdevlogLH.ARMV4I.cab'
Target: '\UserData\SFdevlogLH'
DevMgmt Id: ''
OEM String: ''
Version: 0.0.0.0
Checksum: 0x28b03ede
SUMMARY: 0 Warnings 0 Errors
in rosso la riga di comando per il tom tom
mentre questa è una vettura senza.
Database Id: {C8186B17-1D83-335B-E54D-0C988B1C9C36}
Entry id / size: 0 / 2840
Package Id: {7AA19B7E-E596-439B-B158-D87BABD39C69}
Order: 127805488070000001
State: 'ES_INSTALLED EF_EVENT EF_NONINTRUSIVE EF_INIMAGE ' ( 0x01002060 )
Session: 0x00000000
Name / Provider: 'SMS_Reader' / 'CRF'
File location: '\UserData\SMS_Reader.cab'
Target: '\UserData'
DevMgmt Id: ''
Version: 1.0.1.92
Checksum: 0x1546ffe0
Database Id: {68C877DD-3401-C851-2C18-BD82433F4340}
Entry id / size: 1 / 2840
Order: 127805488070000002
State: 'ES_INITIALIZED EF_FORCE EF_NONINTRUSIVE ' ( 0x00100a20 )
Session: 0x40000000
File location: '\Hard Disk\smart_fdevlog.ARMV4I.CAB'
Target: '\Windows'
DevMgmt Id: ''
Version: 0.0.0.0
Checksum: 0x2df11fcb
come potete notare manca la riga di comando... quindi senza quella il tom tom si collega come una semplice periferica BT ma non funzioneranno le caratteristiche specifiche del tom tom.
La mia giulietta ha il blu and me coi comandi al volante centralina laubher...ed io ho provato a collegare il modello Blue & Me TomTom 2 LIVE tramite il bluandme il problema e o che sulla giulietta dice collegato mentre sul tom tom dice riprova che non e' riuscito a collegarsi tutto questo dopo aver inserito il pin. difatto pero' non funziona nemmeno come normale perifierica tom tom bluandme sai mica il perche? almeno quello pensavo che funzionasse
Il modello vecchio Blue&Me TomTom for Alfa Romeo le concessionarie non lo hanno piu ora ordinano solo quello nuovo appunto Blue & Me TomTom 2 LIVE
Posso risolvere in qualche modo oppure devo crepare cosi? :D
la seconda..... p.s. contattami in pm
Re: E' possibile far montare after market la predisposizione per navigatore tom
Ciao,
vedo che tu ne sai a pacchi su questa questione del navigatore quindi ti chiedo...
Ma alla fine se non c'è il Myport (il buco sul cruscotto per intenderci) il tom tom si puo mettere pero solo con il filo volante?
Giusto?
Grazie
A.
Session: 0x00000000
DevMgmt Id: ''
OEM String: ''
Version: 1.0.13.1
Session: 0x40000000
DevMgmt Id: ''
OEM String: ''
Version: 0.0.0.0
Session: 0x00000000
Target: '\UserData'
DevMgmt Id: ''
Version: 1.0.1.92
Session: 0x40000000
Target: '\Windows'
DevMgmt Id: ''
Version: 0.0.0.0
ciao,
ho acquistato una giulietta con il b&m ma senza la predisposizione per il myport... come faccio a sapere se ho la riga di comando File location: '\Hard Disk\BMd_N_L_4_TomTomLau_199_10130_F.ARM926.CAB' ?
Scusa la domanda. Spero no se ne sia parlato in altri post. Io ho ordinato la predisposizione per tomtom. Ho il blue&me ma ho un navigatore go950 trafic non quello tomtom 2. Il mio navigatore verrà riconosciuto dal sistema??? Posso eventualmente aggiornare il sw del navigatore e mettergli dentro il blue&me?? Anche perchè mi pare di aver capito che il navigatore in vendita nello store alfa è un go950 con il software alfa.
Grazie
Grazie
No, non lo riconosce, vendilo e prendi il modello versione bluandme..... Uno spettacolo.
Ciao a tutti! Dopo aver seguito con interesse il tema trattato in questo thread, ho montato sulla mia Giulietta, con Blue&Me ma senza predisposizione MyPort immatricolata a Marzo 2012, l'occorrente per poter usare il navigatore TomTom B&M Go Live 2 senza vedere fili in giro e con tutte le funzionalità B&M perfettamente funzionanti sullo stesso! È sufficiente acquistare i pezzi (cassettino chiuso e MyPort da un concessionario con i codici già più volte menzionati), montarli in maniera molto semplice, andando a reperire il connettore di alimentazione del MyPort dietro all'autoradio, e scaricare su una pennetta USB l'aggiornamento B&M 6.0 per TomTom Go Live2 e io gioco è fatto! Tutto funziona perfettamente e con grande soddisfazione! Buona navigazione a tutti!:D
