Ecco la procedura per i rolling code, tratta direttamente dal manuale:
Alternative Code Synchronization
To check whether the garage door or gate motor has an alternative code, proceed as follows:
Proceed as follows:
- Read the garage door or gate motor manufacturer manual.
- The portable remote control seems to have programmed to the HomeLink system, but the garage door or gate can be neither opened or closed.
- Push the programmed button and keep it pushed (1, 2 or 3). With an alternative code system, the indicator flashes briefly, and then remains off for two seconds. This sequence is repeated for 20 seconds.
Proceed as follows:
- Locate the “Learn” or “Train” button on the garage door or gate motor. The color and position may vary depending on the manufacturer (consult the garage door or gate manual). Push the “Learn” or “Train” button (this normally activates the setting warning light).
- Push the desired HomeLink button (1, 2 or 3). When the HomeLink indicator begins to flash slowly, move the portable remote control one to three inches from the HomeLink system (keeping the programmable button pushed down).
- Within 30 seconds, push the programmed key (1, 2 or 3) and release it. Push the programmed button a second time and release it to conclude the operation. For some motors, the operation will probably have to be repeated a third time to end the setting.
